How much more leg room is there in a model a coupe than there is in a pickup?? I believe that the coupes have a seat fore and aft adjuster whereas the pickup seats have only one position.
Thanks for any input.
Wonder if this would work on a '31 CCPU?...Took out stock cushions, cut 3/4" plywood panels for back & bottom, covered them with carpet, put piano hinge on front of bottom panel for tool acccess under seat. Mounting 2 curved back bar stool seats...
If I remember correctly, I think there is quite a difference between 28/29 and 30/31.. I think there is more room in the 30/31, but, then again, maybe not..
I will anxiously await the pictures.Carl,
Yes, definately. The curved back of the seat is only about 1 inch thick, which gives you a lot of leg room and it has a nice angle for comfort. The foam filled bottom is about 3 inches thick, so you gain some headroom also. Bill W.
What I really remember is that there was a whole lot more room in my Model A's when I was a teen ager than there is now.
