Left side "bun" panel replacement 26/7 roadster
SUHRsc
Grantville
PA
Price
$250
I started making this panel for my 26-27 roadster racecar but then decided to make the entire side of the car from one piece, eliminating the door, etc.
This is not perfect as I just stopped working on it when I changed my mind about the project.. has a couple dings and whatnot that will need attention
You will need to add your own bracing and then finish out a few areas
I think the photos show pretty well what your getting.
This has the correct bead at the top, so it is a complete sheet metal replacement needing no original parts.
You could make the inner structure from angle iron if your missing the part entirely.
$250 + shipping
or trade for Winfield carburetor or parts, T thru Y-block Speed Equipment, or iron side v8-60 engine. Really anything early ford of similar value.
thanks
Zach
outside
inside
The racecar project
