Yes, but ... you will need to split the brake signal that originally is shared by both taillights into two separate circuits (I did that at the brake light switch), plus depending on the flasher you might need to put a resistor in the flasher circuit to enable the flasher. If the flasher is supposed to enable the stand-alone LED lights it should work OK with the LED taillight inserts.Is it possible to wire LED replacement tailights (the one piece inserts) to a turn signal unit instead of putting additional lights between the two rear bumpers?
Patrick - did you come up with your own bracket for the third light? Would be interested to see a photo of it. Sounds like a good idea. Thanks.Yep.
Fairly easy conversion. 'A' vendors such as Brattons have the turn switch and LED rear bulbs. The LEDs make a big difference.
There may now be a 6v electronic flasher that actually works, but, I haven't found one.
I use a normal thermal 535 flasher and just install higher candlepower incandescents in the cowls and/or front park lights [as turns] to fire the flasher. [ I'm not one to solder resistors in the rear wires]. I mounted an extra original tail light on the spare tire for a third stop light.
JayJay
Are there any LEDs installed that cannot cope with the positive ground?The little lights in my indicator switch do not flash when the switch is activated. Another thing to figure out and fix.
I also got an old turn signal switch for the steering column. One from Arrow Safety Device from around 1920. Fits the car and makes driving more pleasant for me. I'm so used to modern cars.For the turn switch I usually have Signalstat switches on hand. Some don't like the look of them hanging on the column, but, you get used to it.
