Marshall V. Daut
"Amber" alert!!!
Well, I thought I had solved the constantly-on brake and taillight situation in a 1930 Roadster I am trying to straighten out. I replaced the incorrect brake pedal rod with one that has the flat stopper to push on the brake switch's plunger. After adjusting its throw to turn the brake light juice on and off, I find that the brake lights won't come on. The taillights are the LED conversion. The upper amber portion is supposed to have two brightnesses: one for operating at the same time with the red taillight (as the lights come from the manufacturer) and a brighter amber light for the brake lights. I have tried three brake light switches (all used) and found the switch is not the problem. If I swap wires from the new main wiring harness in back so that when the green wiring harness wire (the brake light) is temporarily connected to the black wire of the taillight portion (red lower lens), the lights come on (dual taillights) as brake lights. I have clipped the green wires inside the lights so that they operate as original, meaning red for taillight and amber for brake lights. Snyder's instructions tell how and why to so this.
So, power is getting to the taillights via the green brake light wire. But nothing happens when I connect green-to-green and black-to-black wires other than the red taillights turning on. In other words, the brake lights do not come on in the upper amber portion.
Because this car came to my friend with the taillights and even brighter brake lights constantly on due to the incorrect brake pedal rod, I am guessing the brighter amber electronics eventually burned out, or whatever kills diodes. I am also guessing the brake light function in these taillights is D.O.A. from constant use. Is there some way I can check the functionality of those little diodes in the upper portion of the taillights' motherboards with a voltmeter? If so, how would I do that, meaning dial settings and what kind of readings should I expect from a functioning motherboard? What would indicate dead diodes, etc.? Obviously, electrical issues are not my cup of tea.
Thanks in advance to you computer-minded readers!
Marshall
Marshall
