If you fit the correct resistor in parallel (not in series or in line) with each LED lamp you use, weather it be two or four Led lamps then you can use any normal type of 6 volt flasher unit. The resistor simulates the load of a normal filament type bulb allowing the standard type flasher unit to work with LED lamps. Regards, Kevin.
