CW Moss has quartz halogen. Is this my only alternative?
Thanks, ndnchf. Did you get your tail light bulbs from LEDLight too? Do you have part #?
Yes. tail lights are #95634.
I also go the 6v positive ground LED Compatible flasher 84787 for my turn signals. I added a motion sensor 3rd brake light too.
FWIW, I use these in my stock 6v '35 Fordor.
https://www.ledlight.com/p15d-30-led-headlight-5-to-30-volt-dual-filament-non-polarized-ncnrnw.aspx
If the led’s don’t work well with the lenses, should you try the halogen light lenses?
I have never found a LED headlight bulb that actually works in my original Ford 1937 headlight sockets.
