christian
I recently installed a Nu Rex centrifugal timing device as I was always curious about them. I then set out to time the engine but couldn't find my hand crank. I was in a rush and eager to try out the centrifugal timing device so I got out an extra long screw driver, almost as large as a pry bar and stuck it in the crank pulley to rotate the engine. I pulled harder and harder but it wouldn't budge, finally i put all my weight into it and boom, the crank pulley cracked apart. Turns out i forgot the car was in gear and the wheels were blocked.....
be gentle to your crank pulleys please.
