Lean-to-the-left....
Should vehicle be on jack stands while this is done? Or, can it stay on its tires. If jacked, where should jack stands be located?
Thanks.
John
Leave it on the tires, no jacking needed or wanted, except to maybe help push the body over while you tighten the nuts on the high side, as you lift up on the low side.
This is great! My dad's A leans way to the left and he was just talking about how much it bothers him. We'll flip the rear spring 180 and let gravity work out the rest over time. Thank you.
A friend works on 'A's all day long at a local 'A' museum - I mentioned I had this issue. After he asked if this was only a problem when I was in the car... :rolleyes: he showed me a coupe he was working on that was leaning to the left...
As you look at the rear spring - the center bolt should be, well, centered between the U-bolts. What he showed me was the center bolt shifted to the passenger (right) side - obviously closer to the right U-bolt - pushing up the right rear corner, which was forcing down the left front giving the list to the left.
He ls going to loosen the U-bolts - carefully jack/lift the body to move it to the right to re-center the center bolt and then tighten the U-bolts to hold it in place again. He's done it on others and indicates that has solved the issue for him each time.
Your mileage may vary...
This seems to be a tricky thing to fix.
I've recently replaced both front and rear springs.
The front was just worn out.
The rear had a snapped off center bolt which let most the leaves to shift to the right side.
Someone also bent up the 2 lower rear leaves for some reason.
I had a 2.25" lean to left measured at both fender openings.
Now I have a 1.75" lean to the left and the car sits 2" higher in back.
IT frustrating and my Model A friends have been very patient with my problem.
I guess replacing both springs/shackles with new units are only a partial fix.
Any ideas would be appreciated.
Rather than flip the rear spring 180, what if you pulled the center bolt and flipped every other spring 180? Would not you equalize the error?
