Pluck,just where is your ****** leaking? Mine started to leak around the rear of the countershaft,I just bought one of those $15.blocks with the nylon washer to stop it.Not original but it worked.My uncle parked the car in 54,gave it to me in 68,I've driven it off and on since 72,and pretty steadily since 86.Some of the hardened oil probably finally gave way and started to leak.Three years ago I took out the straight motor honey that had been it there since 72.I prefer to take out the rear end to take out the ******.I have a lift so the hardest part to me is taking out the mat,floors,and battery without scratching anything or getting anything greasy inside the car.Pete,if you have gear oil in the U-joint housing,and not dripping a lot I call it a good thing.If it migrates to the rear end too fast it can be a little bit of a problem.That gooey oil is getting into and lubing the joint.An old fellow I worked for drilled into me not to use high temp grease in certain things,although he loved the stuff.He claimed high temp grease would get slung out of the way in a U-joint and never get hot enough to melt back into the important parts.Made sense to me so I still do things his way.
