Leakless water pumps... is it me?
I installed a leakless on my Tudor last week that I bought from Snyder's. It has a small paper that came with it and it said to grease the rear and the front is sealed. However it chirps every now and then for a few minutes straight. I removed the rear grease cap and tried to add grease to it, but none will go in. Yes, the packing nut is loose to allow air to escape, still no go. No, It's not the pulley rubbing on the pump.
I'm keeping an eye on it.
Regards
Bill
Are you sure that it's the pump "chirping"? My'31 CCPU had an infrequent chirping that I finally tracked down to the front motor mount.
