Today I helped a club member replace the fan hub on his leakless water pump.
After I installed the new fan hub, I noticed the brass "packing" nut was completely loose. How tight should it be, or can it be overtighten. Since it is a leakles pump I assume that is has a different sealing system compared to a standard pump.
