I bought the pump from mac's about a year ago. I tried to call them but their customer service leaves a lot to be desired...
I was curious enough to press it apart. The bearings are all sealed and it has a mechanical seal that is spring loaded. I believe the problem is the seal allows coolant to to get around the seal flange and drain from the weep hole.
I'll end up eating this and buying a quality part.
Thanks for the help.
A lot of pumps are a carbon and ceramic seal set up which are long lasting IE pool filter,dishwashers.
It doesn't take a lot of ability to graft one of those seals into a Model A water pump - can't be - I've done it.
