leaking steering box
I have been using John Deere Corn head grease in my steering boxes and works great no leaks. I use it in all my cars don't need the mop any more.
There is an steel end plate with a brass tube crimped in the center. The horn rod passes through the brass tube. If you remove the end plate and inner tube you can silver solder the tube to the end plate. The tubes usually crack at this point. If your not ready to do either repair and the corn head has run out of the box, there is not much more that can be done.
WILL....."Copied & Pasted" from an earlier thread from Terry,OH. Terry usually has a pretty good handle on how the cow is supposed to eat the cabbage. DD
