Leaking rear axle seals
hewe
If you have leaking rear axle seals this is the time to fix them with Durasleeves. No need to buy new axles the fix is cheap and permanent. Durasleeves go on the damaged area. They are hard chromed for long life. They are made specifically for the Ford A axle. Kit come with instructions, and sleeve installation tool.
Contact Hugh Hunter. hughhunt@telus.net
You're about 3 days too late! I've just assembled that stuff and to overcome the wear in the axle, I made a spacer about 2-3mm thick that I glued to the new seal. When I installed the seal, it was a little closer to the diff than it was before and will run on a new piece of axle.
I'm still loking for a couple of good second hand axles though.
