G
Guest
Guest
just fired it up , while filling block w/h20 water started leaking out the sides , top etc . heads were surfaced , block is super clean , re torqued after hot , but still leaking . dont think any going into cyls . runs good . used a copper sandwich made by "best" ?? did notice when torqueing , the center of the gasket was oozing out sides . is this normal ? should i go to reg gaskets ? thanks
