I cant believe you said that. Gasoline and Teflon tape do NOT mix. It will eventually soften and end up in the carb. Great for a carb clean out job. Thank you. ken ct.Use Teflon tape but keep it back off the first two threads. G.M.
Im with you TJ, bad advice from some one who should know better. ken ct.The plug is a pipe thread. I would never use teflon tape on a pipe thread or around gasoline.
