leaking gas tank at steering column bracket
The 31 bracket will bolt directly to a 30. A 28-29 needs a spacer.
John
thank you all for your thoughts, at a closer look it appears, that one of the previous owners tried to fix something on it, so I will drain the fuel, dry up the gas tank, remove all paint and other stuff at the area around the support plate, will wash it with azethon, let it dry, light a candle and try to seal it.....
Best Greetings
Albert
How much disassembly of the dash is required to install the support bracket? My tank is not leaking, but I see this as a good preventative measure. Just wondering how much trouble I will be getting myself into before I make the attempt. I have a 1930 Tudor.
Thanks
If it's not leaking now, then just leave it alone, and do not grab the wheel for leverage when you get in the car.....that is the main reason for these leaks.
Thanks
As previously noted on the 30's it is bolt on. I added a third bolt by drilling an extra hole to match the center hole in the new bracket. You might also want to check your steering box mount bolts for wear as the column flexing with the tank mounted bracket will cause them to work and wear.
John
Right hand drive difference?
John
Probably, but I would think that a small wedge would take up any slack that was found. Even a roof shingle could be used to compensate for the dash rail variance.
If your gas tank has been abused enough to start the leaking, it is not only time to try other things, but also time to get the tank out of the car before something serious happens.
A wedge would be super ugly and not the way I'd like to go, though it might work for some. Try holding one on the other side of the car and see how far off it is.:eek:
Fitting a steering column support in my case is not a matter of trying to fix a leak, rather trying to prevent one starting. On a couple of my cars, bought in the US, I needed a support when I converted to RHD, again no leak involved. In addition, the support I make is ideal for mounting a couple of instruments and warning lights (like turn indicators). I don't like instruments mounted under the dash where they get in the way when releasing the hand brake. On the support is an ideal place for me and they are close to the driver's line of sight. For the car we use to tow our camper, which is fitted with electric brakes, the controller is mounted on a bracket screwed to the support.
A wedge would also not be seen because it mounts to the upper tank lip and is behind the dash rail.
Just a thought.
Thanks[/QUOTE
Chris, the only thing I did was to take off the panel that goes across the dash. If I remember there are two screws on each end. I put the bracket on both of my rigs. They are 1929 models but I used the brackets that are used on the 30/31's.
I purchased them on EBay but you may be better off to purchase them from one of the vendors. I found that there were two lengths. The first one I got and used went on without much effort. All I had to do was drill a hole in the dash for one of the bolts. The other bolt fit in one of the bolts that bolt the gas tank to the body.. The second one I got and installed was a bit longer so I had to "file" it down a bit to get it to fit.
If you like I could send you some pictures. Just PM me with your email address and I will send.
