leaking fluid ?
I got the A started! The first time in 44 years.. took it for a short spin 1 mile of so and everything seemed to work.. then when I got back I noticed a oily fluid that looked a bit on the greenish side, looks like it could be the transmission. Any ideas what this leak is ? What needs to be done next?
Bill - Give us a little more info. Is it coming from the ******; if so, is it from the front or the back. You mention the fluid has a greenish look to it which makes me believe it might be anti-freeze. If so, one wouldn't think it would be coming from the transmission but from somewhere on the cooling system.
Did you notice the fluid on the ground, or was it on a drive train part. Keep feeding us info and it can be narrowed down.
Thanks, Ron/IA
The 600W I got from the vendors a few years ago has a somewhat greenish color to it (in the container). Again, what is the location it's coming from?? Are you running a/freeze??
Paul in CT
Attached is a photo.. hope it helps I think it might be the flywheel ? I am really new to working on this thing... so I don't mind looking like a idoit at this point... looks green in the light but on the floor it was oilly (not green), like motor oil. not greesy and not very heavy. I am looking forward to getting this fixed so I can get on with my bringing this back to life. It was a trill driving it yesterday! Let me know if the photo helps. Thanks Bill
