Leaking/flooding Carb problem solved
Ed Pitts
Thought I had a problem with the power valve leaking by. As it turned out, the brass float had a crack in it and was full of gas. Replaced the float and the leaking/flooding problem solved. Ed
a sure sign of a good mechanic is he checks all the easy stuff first, doesn out smart himself by thinking up all kinds of complicated things to check, seems that you have the dianostic skills to keep your ride running, way to go
