fordfun
I continue to work down the list of problems associated with the 1929 Sport Coupe I acquired 2 years ago, and I’m about to tackle a leaking exhaust manifold. As you’ll see in the attached photo, the system is equipped with an Auto-Lite heater unit. I have not removed the unit(s) from the engine yet as I’m attempting to extend the driving season a bit and I don’t have any replacement gaskets in hand yet.
I have a few questions:
1. If I find that the manifold is damaged (cracked, warped, etc.), can this type of damage be repaired or should the unit be replaced?
2. If replacement is required, is a “special” manifold required to accommodate the heater and if so are these available from the vendors?
3. I’d like to refinish the painted members. Would you recommend stripping, blasting, or some other method of preparation?
4. Are there any other obvious problems indicated in the attached photo?
5. The car tends to backfire when going downhill. I recall reading elsewhere here that this may be caused by a manifold leak. Does that make sense?
