Art Bjornestad
Just discovered a leak on the front of my '31 block. It's on the very front where the block goes toward the rear after the water pump and the heavy cast area where the head bolts to. I have to use a mirror to see it and looks like at least 3 very small holes where it has rusted through.
Will Block Seal made by K&W stop this? I can not afford to pull the engine to get it welded. I was thing of using the block seal and some JB Weld after I dry it out. Any ideas?? Thanks, Art
