You'll have to cut out the rubber gasket from the glass and then remove the windshield. Place the windshield in a new gasket and then place heavy string or some small gauge wire around the channel. Once that is done you will need a helper to hold the glass on the inside of the car while you are outside with the string/wire in your hand and slowly start to pull on it. You will see the rubber come over the edge. If it;s too hard to do that you may want to soap up the channel before you start. Just go all the way around shifting from one string/wire to the other until you're finished.
Good Luck
