Rich Fallucca recommended a half tube of copper or aluminum radiator sealer.
I took his advice -- one tube did two engines (easy math)
Are you saying to coat the head gasket w/radiator sealer? Is the sealer in a tube thick like gel? Or?
he means to use technician in a can
What the heck is "technician in a can"? I tried Google but even that usual find-all didn't give an answer.
Bruce, I'm trying to understand what you "clearly stated". Radiator sealer that I'm familiar with is a liquid, so I don't see how that could be effectively used on a head gasket, methinks it would just run off.
