Carl,
I will give you some of my own numbers, but they are certainly not any standard to judge by.
Using a setup with the correct 0.040 dia x 0.250 long x 60 degree entrance reference orifice and 100psi input:
My bone-stock 40B with 22,000 miles:
Tested after 1 hour cool-down, runs 15-W40 oil
Leakdown: 91, 93, 88, 91. Compression: 62, 62, 56, 60 (stock head)
My 160B with 6,000 miles, modern valves with 3-angle grind seated on inserts, oversize 1.75" intakes,
modern narrow rings with moly filled top,
honed with torque plate, finish plateau honed:
Tested after 1 hour cool-down, runs 20-W50 Mobil 1 synthetic oil
Leakdown: 95, 97, 94, 96. Compression: 160, 162, 160, 158 (117.5cc head, chev pistons)
Engine I ripped down, had metric pistons, mileage & oil type unknown:
Leakdown: 78, 80, 85, 12. Compression: 52, 48, 56, zero
FWIW, to keep the engine from rotating I put the trans in 3rd, hand crank to TDC of a cylinder with car moving forward, then pull the hand brake to lock the drivetrain.
