It's my understanding that, (in the '30's & '40's), Ford recommended using Amoco "white gas", the equivalent of unleaded gas at the time. I’ve run unleaded gas in our Flatheads for years… never had any gas related problems until the “corn” gas they have now, started eating the rubber in the fuel pumps, etc.
do any barners use lead substitute in your gas.
I think lead additives didn't come in until the 50s when higher performance engines were being built, So most of the flatheads were pre lead motors. I don't believe a stock engine would need the lead, especially with those stock valve springs.
My built motor in my roadster has hardened seats but I am running springs that have 200 lbs pressure over the nose of the cam. I run premium gas (which has less octane then "regular" used to) but don't need a lead additive to keep from pinging.
Ethyl gas with lead came out in the 1920s.
I've used Kemco Lead Supreme 130 in my tow vehicle and high performance vehicles for years. . . . This stuff is not a lead substitute, it is real Tetra Ethyl Lead. . . .
In CA ("For off road use only")
