Zimmco
When I took the pan and cam gear cover off my LB engine to check things out, I found that a modern lip seal had been installed when it was rebuilt years ago (and not run). The front pulley has a spiral cut in it to work with a rope seal, so I'm concerned that the spiral could wear a lip seal quickly, and oil could leak past through the spiral when it's not rotating. Any opinions on whether I should I go with a rope seal? If so, should the rope seal be put in with permatex or silicone?
Al
Al
