Newbie question:
I have a Laycock J type OD. From the threads, I should use 30W oil if it's old type; ATF if it's new type. (1) So how do I tell if it's old or new? Will ATF work either way? (2) There is no plug on the side. How do I put fluid in it? (3) How high should the level be on the visible tube?
I got the car last week. It was delivered with the OD engaged. It was backed out of truck in reverse, and I backed it up a couple of times, maybe a total of 40 feet before I learned that was not allowed. It does not appear to have a safety circuit for reverse. When driving down the road, it will engage the OD, but sluggishly, like it's an oil problem. Any comments would be helpful. Thanks so much.
