willowbilly3
I scored a field find 36 Deluxe coupe yesterday. Engine is missing but it has a transmission. I have acess 40 truck engine or a 42 truck engine, what would I need to bolt one up?
Thanks, I will be learning a lot on this car and will probably need help. And it will need a steering gear I suppose. Typical old field car, steering probably locked (key missing) and froze up tight. I've parted quite a few 30s and 40s Fords but not attempted to make one go yet.The 35-36 Fords did not have drip rails. The roof line has a gentle concave roll down to the upper lip of the door jamb header.
It is easier to use '35-36 exhaust manifolds on a 37-48 engine installed into a '36. they clear the steering gears very nicely. Headers are not a good idea.
If you want the car to drive nicely convert the car to '37-40 steering gears.
If you PM me I'll be glad to answer any questions about the how to's of a '36 Ford.
I wondering about that too. The 36 transmission bolt circle sure looks a lot smaller that the truck 4 speeds do.Will the larger truck pressure plate interfere with the 36 bell housing on the transmission? I ran into this once.
