latecomer
Look guys, he said he changed all those parts and got it running. I believe he said it ran well for 15 minutes. So I don't think it's compression. If it were it wouldn't run well when it does start.
It has to be an intermittent problem with spark or fuel. We need to eliminate one. I would start with eliminating a fuel delivery problem. That's very easy to do. Then proceed to check electrical .
Latecomer when you changed your distributor plate did you check the lower plate wire?
