If I was going to put an 8BA in a 34 this is what I'd do. Install a 59AB cam, and front cover, dist down front, use 59AB water pumps, plug one water hole in the block above the pumps. Use the 2in. spacers under the motor mounts. Speedway sell them. Use 8BA truck oil pan and truck adapter plate on back of engine. Use the 34 gen. with fan. Use 39 crank pulley. Walt
