Late 31 pickup seats
mtd1960
Looking for ideas for late 31 pickup seats hoping to find a reasonable solution
( not a correct restoration). Plywood / foam ?
I have reproduction CJ-5 seats in my late '31 pickup. They work great and look like they belong.
Plywood base and foam from a golf car seat. Covered with a plastic seat cover for a 50's bench seat, fold the cover to fit and staple in place then trim excess. I harvested some foam when I worked at an E-Z Go dealer, it is designed for this type of seat.
Perhaps by the time and effort spent to find options, one can purchase the correct springs and wood frames from the vendors.
Third seat (removable) from a mid 80s-90s Dodge/Plymouth minivan. Works great with a metal frame under it.
I used a middle row seat from a Caravan in my Coupe - only cost $100 - was intended as temporary. Not quite as comfortable as a true Model A seat but it works so well I have kept it. Someday I will recover it with more authentic material.
It has a plywood base attached to the original runners and the seat is attached to the base with door hinges so it can tilt up and be easily removed by pulling the hinge pins, also reclines. I had to bend the tilting mechanism arm but other than that it fits perfectly and matches the Classtique interior quite well.
