Late '31 oil pan tray for Model A
modelaer50
New member
Auburn
WA
I am looking for a late 1931 oil pan dipper tray, the one that is lowered 1/8 inch in the oil pan. The bead is moved up on the sides of the tray by 1/8 inch over the earlier trays. You will see the difference if you compare the bead location ( where it snaps into the oil pan) compared to the earlier version. The late oil dipper tray works in conjunction with the oil pump shield introduced with the lowered tray, per Model A Ford Service Bulletins Complete - page 296, July-August of 1931. These pans were also used on the Diamond engines, including ones used on Baldwin Combines. I'm just interested in the tray, but will consider the complete tray and oil pan.
Thanks, Bob
