ctlikon0712
I want to start a thread cataloguing all the differences that the late 31’s had, this is a little selfish on my part as my car is made in April.
But it should help and enlighten others as well.
I have the Judging Standards but they aren’t with me at the moment so I’m not %100 on all this. Therefore thoughts and corrections are welcome. So here goes!
Indented firewall
Fuel shutoff at the firewall
Side bowl carb Zenith 2 & 3
Larger Oil tube and B style filler cap?
Straight pole coil
Exhaust manifold with added matl. At the downturn
Steering column mounted to the dash instead of the tank
Instrument cluster with groove around border of the ridges
Shocks with large ears and arms with HE stamping with thick shoulder at the shock end
Thin wall shock end links (smaller diameter)
Brake backing plates with adjustment boss turned down ¾ around with a flat on top?
Steel, one piece 2 blade fan
Distributer casting had different bosses for the spring straps?
Cast iron brake drums, solid rear and 5 spokes in front
Throttle assembly with conical return spring and column rod pivot, mushroomed or riveted on
Oil pan differences? Splash pan lowered and different drain? Shielded oil pump?
Indented firewall
Straight pole coil
