Adam/Mill Valley CA
I just finished installing my newly rebuilt ****** (which works fine)on my '36 pickup -it had been sitting for about 6 -8 weeks. It has developed a massive (>1 quart in 35 miles) oil leak now from the cotter-pin hole at the back of the oil pan; this is completely new (it always seeped a little bit from the front rope seal). I did remove the clutch to check the flywheel runout(which was fine) but that's as close as I got to the engine itself. I know these babbitt-bearing motors don't have an actual rear main seal. There's nothing I can see leaking from the top of the motor. Any ideas as to what might be going on?
Adam
Adam
