Thanks Rex !!Dont you just love it when a plan comes together , Good luckon that Tony. Rex Modesto
Tim thanks for asking , the first sample cam to grind a master from has too much run out on heel of exhaust lobe . We found this while plotting cam on Friday . We are now working on getting original master & also looking at other originals to make a master from. This has slowed us just a little , but we have several options .KiWinUS:
How's the project progressing?
The cam I sent you is from cam techniques , I never got around to installing it.
what will it take to correct it? are you saying the heel has high and low spots?
maybe from grinding wheel chatter or looseness from the machining?
is the problem just on the exhaust lobes?I need to know so I can check the others I have and possibly correct the problem.
Thanks,
Fordestes
Alrighty guys ... The KiWi-L100 is born , get your cores in now !!!
Check out the thread on the GREAT KiWi-L100 cam
Cheers
Tony
