These spec's are on Cam Techniques letter head posted to me with the cam about 3 yr's ago.
Grind......L 100-10
Valve lash..
Int............016.........Ex.......018 cold
Lift.
Int........ .375.........Ex...... 375. at cam
Duration..
Int........ .270*....... advertised....... 246* at ..050 cam lift...
Ext....... .260*........----------....... 238* --------- -------...
Valve timing at .050 cam lift
Int.opens 17 BTDC closes 49 ABDC
Ex.opens 53 BBDC closes 5 ATDC
These timing #'s indicate 4* advance 106* Int. C/L...
They're some small differenses in WGA's post....I'm not sure why ?
A great cam !........
David grinds a Blower version of the L-100. I don't recommed running a new engine on a run stand very much, this will keep from seating the rings without a load.
