Don
Found a chart on VP site saying the dist contact PERCENT of points being closed for 35-36 is 60% which works out to 27* of dwell.On the later years the percent of contact is 50% which equates to 22&1/2 * ,these are for the firing side.I understand 26/27 is what the firing side should be..37 total. I have always set everything to 22 1/2 * using the KRW tool as the instruction say, Question ,,,shouldn't I be setting everything to 27* on the KRW using the degree slide.,,I think this would make the sun machine read correct or a lot closer..
Found this also
Dwell = 360 divided no of cylinders times
[% duty cycle divided by 100]
To cold to go outside,,,,,
Found this also
