The KRW 9350-A is a carb and fuel pump tester. It sits on the counter and the resevoir is filled with kerosene. It has an electric motor that runs the fuel pump just like when its on the car.The gauges tell how much fuel press and pump vacuum you have and you can connect the fuel pump to the carb and check for leaks ,set the float level and make other adjustments. The other tool is a bench mounted holding fixture for rebuilding fuel pumps.
would you consider selling the bench type carb rebuilding fixture? MarkI own one of the Bench type Carb Rebuilding Fixtures. It was NOS when I
Found it. Dereald
