BRENT in 10-uh-C
I have decided to build a tool wall (8' tall by 8' long ~ two-sided) to hang all of the specialty tools we use in daily mechanical restoration. At the advice of Will Cronkrite, I bypassed the use of 'pegboard' and purchased four sheets of ¾" pine plywood for the sake of sturdiness. As we started laying out the tools on the floor in a 4'x8' taped-off area, I realized this ain't as easy as it once appeared due wanting to make sure that tools were grouped properly (engine tools in one section, trans tools in another, rear end tools in yet another, etc.) ....PLUS allowing room to be able to add additional tools should the need or availability happen at a later date. Does anyone have any diagrams or pictures showing tool storage of KRW or other specialty tools?
Maybe some suggestions too? For example, --on distributor rebuilding, there is the homemade bushing driver, the reamer, the specialty aluminum cap that we made to clip on the top to align the reamer, the gauge to check points, the screwdriver with the locking tip, the homemade tool to remove the oiler, ...and I'm sure I am leaving something out too. Keeping these all together has its obvious advantages as you can see. Then we move to the carburetor, --or the generator & starter, and other areas that require multiple tools to rebuild. What do you think is the most efficient way?
Thanks!!
Thanks!!
