- City
- Baldwinsville
- State
- MA
- Price
- $450
Complete set of KR Wilson main bearing quick bolts. Fitting a crankshaft to the bearings requires putting the caps on and taking them off multiple times. If you are using the original main bearing bolts this involves a considerable amount of time.
To speed up this work Wilson sold a set of Quick Detachable bolts and keepers with each main bearing boring and reaming jig for Model T or Model A that was sold. Loosening the nuts by just one turn allows the keeper to be removed and the bolts to be pulled out of the block. The QD bolts typically save 30-45 minutes time on a main bearing job.
This set has been cleaned and carefully inspected. They are in very good condition and will serve for many years to come if not over tightened.
