Kr tool
DEUCEMAN
FONT="Arial Black"][/FONT]
I HAVE K R WILSON TOOL IN SUPER CONDITION BUT I HAVE NO IDEA WHAT IT'S FOR. IT'S OLD THAT'S FOR SURE AND IT LOOKS LIKE SOME KIND OF A 'PULLER'. THE NUMBER STAMPED ON IS IT CLEAR; T53T-4222-A9. CAN ANYONE OUT THERE TELL WHAT IT'S FOR AND HOW DO YOU USE IT. I OWN A PERFECT AND REAL 1932 HIBOY WITH AN MAX BUILT 59A, '39 TRANS WITH LINCOLN 25 TOOTH GEARS AND A '40 REAR WITH 4:11 GEARS. IT'A A RUMBLE SEAT ROADSTER.
IF ANYONE KNOWS WHAT THIS TOOL IS AND HOW TO USE IT, THANK YOU....
Thank you for your reply. Sorry but I do not have the capability to post photos. It says; KR Wilson, ARCADE, NY. than the number T53T-4222-A 9 it's the strangest 'puller' I ever seen. large center bolt, two T's one with prongs that are about 1" long with split ends another with 2 bolts course threads 1" long. the center bolt has a sleeve over it that's loose and spins over the bolt. It's a heavy duty item....
1953-55 F-250,F-350 & P-350 Remover-Differential Side Bearing Cups.
Reference Ford Special Service Tool Inventory Catalog.
Thank You Slick Willy, that's it! and Thank You Gary in LA as well for identifying it. Now that I know what it is and what it's for I have no use whatsoever for it. If any one wants to buy it, let me know...Thanks to all.....
On the later KRW tools, the number like 4222 is the basic Ford PN, so you can see what part of a vehicle it is for from any parts catalog. The other parts of that KRW number describe the application. In earlier KRW usage, numbers like AB-123, the usage prefix is nice and easy, but the part application is entirely unclear!
