FURTHER TESTS AND OBSERVATIONS AS REQUESTED
1. Sound does not go away on its own if clutch is not depressed.
2. Shorting plugs, one at a time, had no effect on the sound.
3. Using the stethoscope it seemed like the sound was coming from the front of the engine, perhaps around the timing case or the pully. I am not very experienced in use of the stethoscope, so I can' be to sure of this observation.
4, Background:Symptoms developed gradually over a period of approximately four hours of run time consisting of around 8 short trips and one longer run of 15 miles. At first the sound was barely present at startup but seemed to disappear once I started driving. When I started it up today it was blatantly obvious.
Here is another item which, looking back, might be related: During this same time frame I noticed that when up shifiting when I put in the clutch the engine seemed to growl or buzz as though something was loose. I could avoid the sound by shifting very gently with minimum RPM.
Thanks so far.
Any more recommended tests?
