allen
Hi guys built many Flatheads all ran very nice never had one give me this much trouble, First lets start with everything is new 4 inch crank, all valves are new and springs cam bearing ever thing, the knock is odd at idle you hear it in the front when rev you hear in the rear not the oil pan but in the bell housing, the crank was taken back out and double double check new bearing again installed look over ever thing saw no marks at all looked great. once again install ever thing fire her up and its still there, all rod and pistons were checked by me and the machine shop, think it might be the cam can the cam thrust back and fourth causing a knock, the cam gear has been replace with a aluminum then fiber. the oil pump replace twice with new ones the lifters are adjustable all settings has been check and check set at 13 and 15, thanks for any ideas AL also oil presurre is great idle 30 high rev 50 psi
