doug.nichols
Hello folks,
Trudy developed an engine noise that met Les Andrew's characteristics of a rod knock. I dropped the pan to adjust bearing clearances (my first time). The good news was that there was very little sludge and the oil pump was spotless. The bad news was that I found metal pieces in the dipper tray (see attached picture). So, I have some questions that members may be able to help me with:
1. Does it a appear that the pieces are from a babbitt bearing? I have not yet taken the caps off of the rod or main bearings. Attached is a picture of a rod cap in case that is helpful in answering this question.
2. Whether it is a babbitt or i
nsert bearing, it it possible to replace a single bearing with a new insert bearing with the engine in the car? I am not aware of anybody in my area who works on Model A engines and I am not set up to do so. Should I be prepared to ship the engine somewhere for repairs?
Thanks for your help.
Doug
Doug
