I am in the process of going through the front suspension on my 30 coupe. Couple of problems evident...weak front spring and a lot of up/down play on the driver's side spindle. So this morning I disassembled the front end and found that the upper kingpin bushing was turning within the spindle and was a loose fit. This is supposed to be a press fit. The bottom bushing is tight in the spindle. My question is, "Has anyone seen this before? Is it a commonplace problem? Could it be the result of the use of an inferior/undersize part (the front end was rebuilt in '78). The bore in the spindle appears to be smooth, but I have not measured it yet, relative to "roundness". Does anyone know what diameter this bore should be?
Is there a simple fix? My thoughts were perhaps to turn a new upper bushing out of whatever material is used such that it would be a press fit in the spindle. If I go this route, does anyone know what type of material to use? Brass? Bronze?
Thanks
Thanks
