If they are the later pins they will have the lock pin notch in a different spot too.I've bought quite a few of them mixed up in box lots at flea markets.I'll bet they are the later pins.
Ok, here's a back side view. The one on the left is one pin from the first picture. On the right is a current Snyder's Model A repro. Do you still think the one on the left is a 1932-34?
Put a straight edge across the flat spot on the shaft and another straight edge across the open cup face, and see if the straight edges are parallel to each other. If they are, then it's Model A, and if they form an angle to each other, they are for a Model B.
Tom, They are not parallel, so they are "B". They came out of an "A". Someone ground the brake shaft housings to fit . The brake shaft housings sure do fit loose in the cups.
forever4, I believe the one on the right is a USA repro.
