I'm working on the front end of my parent's 29 model A. We have new king pins and had new bushings installed into the spindles. There is vertical play between the axle and the spindle. I have 2 thin shims and another thicker washer deally with a rolled shoulder. In order for everything to line up properly including the locking pin groove, the thicker part needs to be on the bottom and the shims on the top. However the weight will certainly crush the formed washer part. What is the proper method of shimming this? Also the new locking bolt is different than the original. It is smaller and has grooves in it. It doesn't exactly slide into the hole. Is this normal and does it need to be beaten in? Thanks.
