I have a 1958 ford ranchero that im restoring. Bought new key locks for doors and new lock pawls. Problem is the key will unlock door but it won't lock it. Any ideas? I don't see anything in manual.
The little fork that ties the lock cylinder to the latch assembly can be installed 180 out and feel OK. Or the fork may not be inserted properly. It will not unlock the door. Getting it in is a little tricky as the longest portion of the "fork" needs to go into a hole in the lock mechanism. Given it is "floppy" getting it inserted will try your patience. They are also right/left parts.
