Mike, I have heard this before, but I think you will find that if you study the pump. That restricting the stroke of the pump effectively reduces the VOLUME delivered. The delivery pressure is solely effected (caused by) the big spring, that is found under the diaphragm.
.Trainguy and KenCT, Ford has recommended (specified) different delivery pressures for the range of carbs it has used over the years.
Before you rubbish the Chinese made pumps for delivering too high a pressure (and Ken, you might well know, and they might well be rubbish for other reasons), Did you check the application and delivery?
Ken, Maybe you have done so already, but can you explain with some factual details as to why to stay away from the chinese pumps.
Trainguy, Which carb are you running? and what delivery pressure is specified?
What was the delivery pressure of the Chinese pump?
Nobody likes bad press, and undeserved bad press is worse.
Surely free speech carries certian responsibilities.
BTW, I have no Chinese affiliations what so ever.
