If you have not been talked out of it already, send me a PM.
I will send you a gasket free of charge.
Good luck,
Tom
Agree with Y-Block. Do away with the draft tube and install a PCV system. They're easy to fab up, and you can get plenty of help and info on fabbing and sizing the PCV valve properly on this forum. Things like road draft tubes and single well master cylinders are better gotten rid of.
P V C = Polyvinyl chloride = plumbing pipe.
P C V = Positive crankcase ventilation.
__Yeah I say it wrong half of the time too. __
JIM__![]()
I get it wrong all the time. At work we have PCV's (Pressure Control Valves), PSV (Pressure Safety Valves) and PRV (Pressure Relief Valves).![]()
